Enhance Your FlexPendant Web Application Experience: Switch to Chromium Mode
yitong
yitong
edited December 2025 in AppStudio
We highly recommend using the "Chromium mode" when launching the latest web applications on the FlexPendant web app mode. Chromium mode offers superior support for advanced web application styles and the most modern JavaScript syntax, ensuring a smoother and more reliable user experience.
This feature is available starting from RobotWare version 7.17, and it can be enabled on FlexPendant devices running version 1.18 or later.
Post edited by yitong on
  • Is there a way to set the web app mode through a config file on the robot? Also, is there a way to see what mode the system is using from a backup?
    Thanks!
