Target name ArcWelding powerPac
How do I change the target name in powerpac ArcWelding to the one I want (with the correct prefix) so that robot studio then counts up the number for the next position.
// Roger
  • jarmster
    jarmster
    edited August 2025
    did you try creating a point and then modifying the name before you create the next point? i usually just create the points and convert them to in-line points before i copy to the robot. I'm not fond of all the point declarations.
    The option to modify the name is available when you modify the instruction
    Post edited by jarmster on
