Automating RW Add-In Package Installation
jbultman
Is there a way to automate the installation of RW add-in packages to robots? All of my robots are connected to a central network and have custom packages that need updated fairly frequently. Having to connect to each system individually and going through installation manager is a hassle.
I found some python scripts for Installation Manager amongst the RobotStudio installation files. They look like what I would need to tap into, but it is hard to decipher.
To install the package means to change the system of the robots. I don't think there is any interface in SDKs now taking care of system level operations.0
Check this out:
Unfortunately, all of the systems are IRC5.0
Please clarify if you mean actual RW addins or your own custom rapid modules, programs, etc.Lee Justice0
They are RW addins.lemster68 said:Please clarify if you mean actual RW addins or your own custom rapid modules, programs, etc.
Tompanhuhu said:
I can't get the Job to recognize a valid Update package path. I have .rspak and .rmf files, but neither are recognized in the folder.0 -
While reading the robotstudio manual this is what i found.
- 367 IRC5
