Automating RW Add-In Package Installation
Is there a way to automate the installation of RW add-in packages to robots? All of my robots are connected to a central network and have custom packages that need updated fairly frequently. Having to connect to each system individually and going through installation manager is a hassle.
I found some python scripts for Installation Manager amongst the RobotStudio installation files. They look like what I would need to tap into, but it is hard to decipher.
  • To install the package means to change the system of the robots. I don't think there is any interface in SDKs now taking care of system level operations.
  • Check this out:
    If I helped, please press Vote Up  :smile:
  • Unfortunately, all of the systems are IRC5.
    Have you tried Jobs inside RobotStudio?
  • Please clarify if you mean actual RW addins or your own custom rapid modules, programs, etc.
    Lee Justice
    They are RW addins.
    I can't get the Job to recognize a valid Update package path. I have .rspak and .rmf files, but neither are recognized in the folder.
  • While reading the robotstudio manual this is what i found.
