Is it best practice to leave the robot in auto mode or manual mode in idle for robot longevity?
in IRC5
I have a IRB1200. I leave it idle for sometimes days sometimes hours. Should I be leaving it in manual mode with motors off to preserve the motors?
Best Answers
If it has not been moving, I suppose it counts as idle. The brakes engaging will let the servos rest and I expect it would also conserve energy. I checked our newer robots and it seems that the default is now 120 seconds, or two minutes.Lee Justice0
The breaks will always be engaged in manual mode when the Flexpendant's 3-position switch (dead man switch on the side) is not held in the center position.AshTheWaterBoy said:Ok so when I activate Broke on time it will engage breaks after 120 seconds of idle. In auto or manual.
In auto mode, the breaks will engage after two minutes of robot standstill. You will hear a click from the controller, and the drive fans will turn off. The motors will stay on. So as soon as the controller gets a move command, the brakes will disengage automatically.0
There is a system parameter, Broke on time, which sets the time when idle for the brakes to be applied.
Find it in control panel -> configuration -> topics -> motion -> motion planner.
Read up on it in the technical manual System parameters.
It use to be the maximum allowed value by default, which is 3,600,000 seconds, 41 2/3 days!Lee Justice0 -
How does it know when Idle? So in auto mode it will turn the brakes on?0
So it is best practice to leave it with the brakes on?0
Ok so when I activate Broke on time it will engage breaks after 120 seconds of idle. In auto or manual.0
- 367 IRC5
- 858 RAPID Programming
