Has OPUA Client in OmniCore retired I/O Mapping byte ranges?
saitoevc
Had IRC5 configured IO Map with DO_64_bytes and DI_64_bytes. In OPCUA Client Configuration, I was able to see them when dropping PLC DB_64_Byte in "Controller Device IO Mapping" so being able to connect from Dropdown list.
Swapping to new OmniCore, it has retired separated configuration DO/DI so all IO is merged on PN_OmniCore_Device so cannot configure bytes ranges in OPCUA Client anymore only bitXbit...is this correct?
Does anybody have the same difficult?
Thank you all in advance
Any feedback?0
- 858 RAPID Programming
