World Zone
sahars
Hi, how can I create world zone with fixed tool and robot holding the work object? I need to create a zone around the tool so when robot enters the zone set a DO to 1.
That is a tricky one. The only thing that I think might work is WZHomeJointDef. You would have to have really large Delta for the robot joints and it would take a lot of tries to get it effectively set.Lee Justice0
Thank you, unfortunately I need the box to be small and only around the fixed tool area.0
Hi...I didn't understand your position... Do you want the DO to activate when the robot or object enters the area?Good job!0
- 367 IRC5
- 858 RAPID Programming
