Is it possible to combine a key and literal constant?
I want to use the translation function for parts of the text in a label so I dont have to translate the same word more than once.
For example.
I want to show 4 texts to show the status of Vacuum 1 - 4, but I do not want to have 4 translation keys. It does not seem to be possible to use !!Vacuum!! 1 and so on.
//Markus Näslund
  • yitong
    yitong
    edited December 2025 Answer ✓
    Hi, do you want to use code to parse the current multilingual entries in AppStudio?
    You've noticed that App Studio uses !! + key name + !! as the multilingual key, but if you want to dynamically retrieve its value, you can use TComponents.Component_A.t('key name') to get its value.
    like:
    const stringTest = TComponents.Component_A.t('vacuum') + String(index);
    AppStudio is about to release a new version. In the new version, you can get help by referring to the API Documentation. Hope this helps 😆.
    TComponents.Component_A.html#.t
    Post edited by yitong on
  • Hi, you can use classic approach to build custom strings. Like for example: const stringTest = `${string1} ${string2}`; Or you can just add two strings like const stringTest = translatedString + String(index);
  • Hi,
    I don't think you have fully understood my question.
    I know how to combine strings in javascript. What I want is to do it without breaking the translation function in AppStudio.
    I have been trying to combine a translation key with additional text, but so far I have not been able to get the key to translate when it is concatenated with other strings.
    If there is a supported way to combine a !!key!! with other values (for example, an index or suffix), I would really appreciate seeing a concrete code example that demonstrates how this should be done.
    For reference, the following does not work in my case, as !!vacuum!! is not replaced with its translated value:
    const stringTest = "!!vacuum!!" + String(index);
    Thank you in advance for any clarification or guidance you can provide.
    //Markus Näslund
  • Thank you! That is exactly what I’m looking for.
    //Markus Näslund
  • What did I miss here?  It doesn't work and then it does?
    Lee Justice
    The response from yitong answered my question, it popped to the top as is was marked best answer
    //Markus Näslund
  • Oh, I see.  Thanks for clarifying that.  👍
    Lee Justice
