Remove the APP Maker Info tab
How can I remove the APP Maker Info tab from the main menu?
Thank You
Daniel
  • No solution to the problem? Everyone has the APP Maker Info tile in the menu and half a tile for their own application underneath, and nobody seems to mind?
    Daniel
  • Hello, could you please share a screenshot? It will help me better understand what the "APP Make info tab" is.
  • daniel72
    daniel72
    edited January 9
    here is the screenshot
    Folder WebApps contains only the customer project:
    Daniel
  • Tompanhuhu
    Tompanhuhu ✭✭✭
    There is a file called "appinfo.xml" in your app folder.
    This contains information how that icon should look.
    <?xml version="1.0" encoding="UTF-8"?>
    <WebApp>
        <name>My awesome app</name>
        <icon>App_Default_100.png</icon>
        <path>index.html</path>
    </WebApp>
    Restart flexpendant after changing the file.
    If I helped, please press Vote Up  :smile:
  • Where is the file that manages the behavior and arrangement of all tiles in the menu?
    Daniel
  • AFAIK you can't rearrange the tiles.
    Every tile (app) manages itself with the appinfo.xml file.
