Auto mode error when starting arcpack [ArcWelding PowerPac]
Hello, when i start arcpack from the process menu i have been getting an error popping up:
": Not able to set the controller in auto mode retry operation"
IN the output window i am getting " ForceControllerToAutoMode Failed: The NetScanID is no longer in use. Controller removed from list. 26/04/2007 11:09:50 AM"
Does this make any sense to anyone?
"Argon Technology - your industrial robotics and automation partner, helping you build your tomorrow"
I restarted the computer and it seemed to of fixed things.
The old restart the computer trick!
"Argon Technology - your industrial robotics and automation partner, helping you build your tomorrow"0 -
Hi Cole
I get this message often if i am using the flecpendan.
When i set the flexpendant in automode and the start Arcweldpowerpack this message appears.
i then save the station and restart the station again.
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com0
