VC# sample code request
From Visual C#, not VSTA, how can I get to the selection modes in order to set a particular level when a certain event happens. i.e. Clicking in a text window will set the selection level to 'part' or 'surface', etc.
You could do something like thispublic static void SetSelectionMode(SelectionModes mode)
foreach (Window w in UIEnvironment.Windows)
if ((w is DocumentWindow) && w.Control is GraphicControl)
GraphicControl gc = w.Control as GraphicControl;
if (gc != null)
gc.Picker.SelectionMode = mode;
and then just call it with the selectionmode you want for example
SetSelectionMode(SelectionModes.Curve);
You need to add some namespaces as well at least
using ABB.Robotics.RobotStudio.Stations.Forms;
using ABB.Robotics.RobotStudio.Environment;Per Svensson
Consat Engineering0 -
THanks
