IS controler started in VB
Klaus
How can i in VB check if a controler is started or not.
Have read the API doc but can't find anything under proberties to ActiveStation.Mechanisms
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus
Here comes an example how to check if controller is started.
Sub ControllerStatus()
Dim m As Mechanism
Dim c As ABBS4Controller
On Error Resume Next
Set m = ActiveMechanism
Set c = m.Controller
If c Is Nothing Then
MsgBox "Controller not Started"
Else
MsgBox "Controller Started"
End If
End SubPer Svensson
Company Specialist
Here is another example
Function isTheControllerStarted(irb As Mechanism) As Boolean
isTheControllerStarted = False
On Error GoTo errController:
Set c = irb.Controller
isTheControllerStarted = True
Exit Function
errController:
End Function/Martin Lundh
Product manager
ABB Robotics0
