Drag and Drop objects
Hardikez
Hi i have made a AW station with a lot of components and i would like them in a specific order in the objectwindow.
but i cant drag and drop the parts.
Is it not possible ??
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
That is not possible. You could organize them into component groups though.
regards,
Johannes
Johannes Weiman
In the layout mode,follow steps below
1.set up the selection level
menu view->selection level->part or
selection level toolbar->part
2. drag and drop parts
menu modify->freehand->Move or Rotate or
freehand mode toolbar->move or rotate
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
