SignalBindingSources in RAB 5.08
I'm trying to create a view with several radio buttons which all are connected to different digital inputs with SignalBindingSource functionality in RAB 5.08. I have defined own SignalBindingSource for each radio button. The problem is that when one signal goes high all the other radio buttons goes unchecked. So everytime when some signal goes high the correct radio button turns checked BUT the other SignalBindingSources "loses" their information about the input attached to them and the radio buttons goes unchecked.
Does anyone have any experience from this behaviour?
-Oskari
  • osku
    osku ✭✭
    Hi again
    Problem solved, it was my own mistake. I wrongly used RadioButtons instead of CheckBoxes.
    -Oskari
