Problem Saving Stations
sturner
Im getting problems when saving any station in RS5.08.01
The errorr suggests that "one of the reasons may be that there is not enough memory".
This is not the case as the PC has got over 6 Gb avaliable space.
I can Export geometry, and save parts to library. even a station with just a single robot attached to the library wont save.
Im using Windows 2000 IBM net vista desktop
This can happen if VSTA isn't properly installed. To install VSTA, go to "InstallRobotStudioISSetupPrerequisites{B422736E-33AC-47A B-9F9D-15EF74EC4813}" on the RobotStudio CD and double-click "vsta_aide.msi".
regards,
Johannes
Johannes Weiman
Many thanks the problem is now fixed !
- 346 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
