RS5.08 Event I/O connection
Hi does the I/O connection event work in RS 5.08.01. build 2040
I understand that this event can simulate the behaviour of a PLC ?
When I fill out the information the finish button is inactive as if I have I have not completed.
The help file only appears to have refernence to this and not examples.
  • Hi
    Yes it should work in 5.08, at least it did for me.
    In what step can't you see the Finish button?
    You need to go thru 4 steps to make a complete I/O Connection
    Per Svensson
    Consat Engineering
