Disable Close Button in TP Application
Hey all,
I'm trying to disable the close button on my robot application and add my own close button within the application itself. I want to do this so i am able to ask the operator with a gtpumessagebox if he/she really wants to close the application (because doing so results in the robot system going into a controlled shutdown state and subsequently shutting down).
The trouble i am having is not knowing how to disable the close button.
Can anyone please help.
here is a VSTA macro that could solve your problem:
using System.Runtime.InteropServices;
[DllImport("user32.dll", EntryPoint = "GetSystemMenu")]
private static extern IntPtr GetSystemMenu(IntPtr hwnd, int revert);
[DllImport("user32.dll", EntryPoint = "GetMenuItemCount")]
private static extern int GetMenuItemCount(IntPtr hmenu);
[DllImport("user32.dll", EntryPoint = "RemoveMenu")]
private static extern int RemoveMenu(IntPtr hmenu, int npos, int wflags);
[DllImport("user32.dll", EntryPoint = "DrawMenuBar")]
private static extern int DrawMenuBar(IntPtr hwnd);
public void Macro_DisableCloseButton()
const int MF_BYPOSITION = 0x0400;
const int MF_DISABLED = 0x0002;
IntPtr win = ABB.Robotics.RobotStudio.Environment.UIEnvironment.MainWindo w.Handle;
IntPtr hmenu = GetSystemMenu(win, 0);
int cnt = GetMenuItemCount(hmenu);
// remove close action and extra menu line
RemoveMenu(hmenu, cnt-1, MF_DISABLED | MF_BYPOSITION);
RemoveMenu(hmenu, cnt-2, MF_DISABLED | MF_BYPOSITION);
Don't forget to add the refernce System.Windows.Forms.
Thanks for your help!0
- 88 OmniCore
- 42 AppStudio
