exception
Robi
Im My Application sometime a exeption "at.finalization" is coming
if i press the botton Ignor then Aplication is still runing
i have not found any way that my application is still runing without this exception
what may be responsible for this exception
thank you
Are you using the adapter class in your code?Russell Drown0
I dont use the Adapt Native class in my Code
but The AdaptNative class is import in my Project ???
