exception
Im My Application sometime a exeption "at.finalization" is coming
if i press the botton Ignor then Aplication is still runing
i have not found any way that my application is still runing without this exception
what may be responsible for this exception
thank you
  • Are you using the adapter class in your code?
    Russell Drown
  • I dont use the Adapt Native class in my Code
    but The AdaptNative class is import in my Project ???
