NetworkWatcher Exception
I'm tryig to use the NetworkWatcher (using RAB 5.09)
I copied exactly the same example on the manual.
I got this Exception:
System.ArgumentException was caught
Message="
Parameter name: url"
ParamName="url"
Source="ABB.Robotics.Controllers"
StackTrace:
at ABB.Robotics.Controllers.Internal.Event`2.Unsubscribe(Url url, EventHandler`1 handler, Boolean internal)
at ABB.Robotics.Controllers.Internal.Event`2.Unsubscribe(IUrlBo undObject urlObject, EventHandler`1 handler, Boolean internal)
at ABB.Robotics.Controllers.Internal.NetworkScanner.remove_Chan ged(EventHandler`1 value)
at ABB.Robotics.Controllers.Discovery.NetworkWatcher.set_Enable RaisingEvents(Boolean value)
at ABB.Robotics.Controllers.Discovery.NetworkWatcher..ctor(Bool ean enableRaisingEvents, IEnumerable controllers)
at ABB.Robotics.Controllers.Discovery.NetworkWatcher..ctor(Cont rollerInfoCollection controllers, Boolean enableRaisingEvents)
at ABB.Robotics.SchiappaIF.C_OnLineStatus.Connect(Object RobotIPAddress)
Here my code:
Public Function Connect(ByVal RobotIPAddress) As Boolean
Try
IPAddress = RobotIPAddress
ABBScan = New NetworkScanner
ABBScan.Scan()
Me.ABBNetworkWatcher = New NetworkWatcher(Me.ABBScan.Controllers, False)
AddHandler Me.ABBNetworkWatcher.Found, AddressOf Me.NetworkAddController
AddHandler Me.ABBNetworkWatcher.Lost, AddressOf Me.NetworkRemoveController
Me.ABBNetworkWatcher.EnableRaisingEvents = True
Catch ex As Exception
Parent.DebugLog.Add(1, 0, "Function C_OnLineStatus.Connect: " + ex.Message)
Throw New Exception("Exception:C_OnLineStatus.Connect:NetworkWatcher:" + ex.Message)
End Try
Any suggestion?
Oscar
Oscar Ferrrato
Additional Information:
I tested it in Virtual controller and in the real controller.
I got the same behaviour.
Someone is using the networkwatcher with RAB 5.09 with success? can attach the code used?
BR
Oscar Ferrrato0 -
it seems that I have the same problem. Do you already have a solution to this?
BR
Rene
Hi!
There is a bug when creating a NetworkWatcher object with the enableRaisingEvents paramater set to false (which also is the case when using the default constructor). The problem is solved in RAB 5.10.
A workaround that should work is this (in c#), if you want the EnableRaisingEvents disabled:
_watcher = new NetworkWatcher(true); _watcher.EnableRaisingEvents = false;0
- 367 IRC5
- 858 RAPID Programming
