Syntax error 40705
Quintrix
After a restore on a S4C controller, I get a error 40700 and 40705.
Strange enough when I confirm the error, the program seems to be working fine, and the robot is working fine.
Can someone give me a explanation on this.
Thx.
Hey,
maybe you get the errors during the restore-process. If all files loaded the system is ok, but only the errors must be confirmed.
If you want you can test something. Restart the system and you should have no errors like 40700 and 40705.
Thilbi
Probably your robot is working because these errors are in a part of the program that never runs. Try to explicitly check the program for errors, form the "File" menu on the TP.
It happend to me a similar thing with undefined variables.
Best regards
Claudio Meinardi
- 367 IRC5
- 858 RAPID Programming
