PBUS Problem With S4C+
Hi, Every Body,
I have a IRB6400 with S4C+ controler that it has BASE and CAN Units.
I previusly have a Profibus conection via Base unit and it works properly.
Right now I am going to install a new sisoft profibus master card (PB-IF-2MS) on PCI Slot, But it needs a PBUS Software that I have not.
Is there any body to help me with this software?
Thanks alot in Advance.
  • 2007-10-01_104842_Pbus.zip
    hi  I have a old Profibus m/s User's Guide, if it can help you..
  • imageThanks a lot it help me but i was going t find PBUS option on S4C+ please help me if you have any?
  • If you are trying to install a regular RobotWare option for ProfiBus, then that option must exist in your robot license keystring and must be selected in the system configurator of RobInstall when you build a new system. You cannot just install new system software after a system is built, you must build and install a new system to add new options, and you cannot install options that are not included in your keystring. If you need to have an option added to a keystring, you must contact your local ABB support organization to purchase the option. They will then provide you with an updated license keystring that you can use to build a new system with the option you desire.
    Russell Drown
