EXT Axis doesn?t move during Simulation
I create a Station with some Positioners, then i programmed a path with AWPP. All seems to be ok, but when I use the Simulation, the Graphic from the external axis doesnt't move. All external Axis values are ok and there is no error message on the VC . Whats wrong?image
PS.: When I open the path in AWPP, mark the whole path and click on the "Move to"  button , the Graphic moves in the right way.
Best regards
Bertie
