AlphaPad error
msalminen
When i try to drop alphaPad on my application I get following error.
What i can do to fix the problem?
Mika
Are you porting an application from 5.07 to 5.08? I think you should check your references.Best regards,
Ingela Brorsson
ABB Robotics, Sweden0 -
No, I am not porting, but making new sw with 5.09.
However - I get it work. Not sure how, but some of my actions helped.
- I remove and add again ABB controls in VS toolbox
- I restart the VS
- I reboot my PC
Anyhow now it is working.
Mika
