RS to M94 Robots
marcus
Have someone already used RobotStudio to M94 robots?
Like IRB 1400 M94 and IRB 3400 M94?
The baseware should be v2.0 or 2.1...
It's working good? Without problems? With some limitations?
Where can I found control files and library files to work around?
Thanks,
Marcus Daniel
Marcus Daniel
ABB Robotics
mobile: +55 11 8586-4960
ABB Robotics
Hello Marcus,
RobotStudio 3.x/4.0 includes baseware 2.1. It's not fully supported though, see the release notes for more information. IRB 3400 is not supported.
regards,
Johannes
Johannes Weiman
You can use a similar robot in "Robot Studio 5.0" to see your Rob targets in space. Like "IRB 1400" M2004, it can bee a small differens in the mechanics between the year model and the dynamic model in RS.... the big differs is the support of commands in Rapid, between the realises. But to bee more specific i need to now the reason of what you want to do.<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
- 858 RAPID Programming
