VSTA - Dimension of objects
apox
i would like to get the dimension of current working objects or objects that are selected. I found the GetBoundingBox method but have problems to use it.
Hi apox,
Unfortunately the GetBoundingBox() method is badly declared in 5.08, which means it's not compatible with VSTA.
regards,
Johannes
Johannes Weiman
Does the GetBoundingBox() method work correctly in 5.09?
The following code creates a runtime error:
Part part = Part.Load("path to cad file");
Vector3 min = new Vector3();
Vector3 max = new Vector3();
part.GetBoundingBox(true, min, max);
Is there a mistake in the code?
best regards, Matthias
Hi Matthias
you need to do it like this
part.GetBoundingBox(true,out min,out max);
Per Svensson
Consat Engineering0 -
Hi!
Thanks for your response.
I have part.GetBoundingBox(true, out min, out max) in my code.
Nevertheless I get a RuntimeError
Hmmm
It works for me, maybe it's the part that's wrong.
If you just create a solid box and reference to that instead
Something like this
Station stn = Project.ActiveProject as Station;
Part prt = stn.GraphicComponents["myBox"] as Part;
prt.GetBoundingBox(true, out min, out max);Per Svensson
Ah, now I got it.
I didn't add the part to the station before calling GetBoundingBox(..)
Shure it didn't work...
Additional question: How do I get a boundingBox of the complete robot?
how about this:
public void Macro_GetRobotBoundingBox()
// Check that we have an active project
if (Project.ActiveProject == null) return;
Station station = Project.ActiveProject as Station;
RsTask task = station.ActiveTask;
Mechanism mech = task.Mechanism;
GraphicComponentCollection gc = mech.GraphicComponents;
Vector3 global_min = new Vector3(Double.MaxValue,Double.MaxValue,Double.MaxValue);
Vector3 global_max = new Vector3(Double.MinValue,Double.MinValue,Double.MinValue);
foreach (GraphicComponent _gc in gc)
_gc.GetBoundingBox(true, out min, out max);
if (min.x < global_min.x)
global_min.x = min.x;
if (min.y < global_min.y)
global_min.y = min.y;
if (min.z < global_min.z)
global_min.z = min.z;
if (max.x > global_max.x)
global_max.x = max.x;
if (max.y > global_max.y)
global_max.y = max.y;
if (max.z > global_max.z)
global_max.z = max.z;
Logger.AddMessage(new LogMessage(global_min.ToString() + " / " + global_max.ToString()));
Okay this could be a solution.
I thought about a feature of the API that I haven't found yet. The bounding box that is shown if you select the robot inside the objects view.
MaWi812008-4-16 11:42:290 -
The Mechanism class also supports GetBoundingBox() since it inherits GraphicComponent
Johannes Weiman
ABB Robotics0
- 361 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
