Question about writing to Rapiddata
Just a small question. I'm writing an array of num data to the controller. The question is. Do I have to read every single entry first, before I can write the data, or is there some better method to do this? You can se how I do in the image below.
It actually works this way, I only wonder if there is a better way to do it.
/PerM
The ArrayData.FillFromString method is meant to be able to write to a RAPID array in one call - BUT
It has just been discovered that ArrayData.FillFromString is not correctly implemented. This bug exists in previous releases as well. As a workaround the property RapidData.StringValue can be used to read and write small arrays in one call (less than 100 num elements).<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
using (Mastership.Request(m_controller.Rapid))
{ myRapidData.StringValue = "[1.0, 0.5, 0.6, 2.0]"; }Best regards,
Ingela Brorsson
ABB Robotics, Sweden0
