Transperent textbox.
I have some textbox that is placed on top of an picturebox. But if i make them trransperent they dont get the backgroung as the image in the picturebox but get the background that the form has.
Can i solve that in some proberties?
Best regards klaus.
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi Klaus,
    Unfortunately, neither the System.Windows.Forms.TextBox or the ABB.Robotics.Tps.Windows.Forms.TextBox support transparency on the device (real FlexPendant). I think it might be possible to achieve what you are after, but not by simply setting a property. I will get back on your topic when (if) I can provide a coding solution. Maybe someone else has done this?
    Ingela Brorsson
    ABB Robotics, Sweden
