License server issue
Hej!
When I use the License Key Request Wizard I get the following error when I press Start:
"No license server specified, please use Software Product Administrator to set license server and try again."
The problem is I have no clue where to find this license server url?
Product: RobotStudio 5.08
Regards,
Johan.
Johan Renb?ck
Software Developer
Sensor Control AB
Software Developer
Sensor Control AB
Hi Johan,
That error indicates that your license ID is for a floating license, but you haven't specified the server that will manage your floating license keys.
To fix this, open Software Product Administrator and select "Action" -> "Specify License Server...". Type the name of the computer where the Sentinel LM Server (available on the RS DVD) is installed.
Johannes Weiman
ABB Robotics0
