Robot Models to .sat
I was curious is there anyway to transfer all the models that I have includeing the robots into a sat file or any other file that can be opened by solid works? it would be nice to have something other people can open up around my work and be able to view the proposed set up with the robots
edit: and i do know that there is an export geometry option, but I would like to export everything at once, and keep it in its relative location
dh_custompak2007-11-29 17:3:0Dustin
Unfortunately is that not possible. The only thing you can export from a RS station are individual parts to sat files.
Hi Dustin,
I have found a way to export the whole station to one .sat file. Contact me at sergej.saibel@allelektro.se and I will help you.
Best regards
Sergej
Sergej Saibel0
