change path colour
Hardikez
is it possiblew to change the colour of a path??
i would like to be able to se all my pathes in the window but in different colours.
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
No that is not possible.
Actually it is
You can set color for the move instructions that make up the path.
To set the color for an entire path, select all move instructions in the path and click Modify -> Set Color.
regards,
Johannes
Johannes Weiman
ABB Robotics0
- 346 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
