instalation of RS10 with update RW versio
Is it nessesary to uninstall the previos version of RS10 in order to install the new version of RS10 with the update RW version.
Dept manager robot welding
Kez@hardi-international.com
Is it OK to keep the original RS 5.10 and just delete RW 5.10, then replace it with RW 5.10.00.01?0
Hi Hardikez
No you do not need to uninstall the previous version of 5.10 before you install the new version of 5.10.
Tonje2008-2-5 12:45:6Tonje Sandberg
Service Training Coordinator
ABB AB / Robotics Products0 -
Hi j_proulx.
No, there has been very importent changes in the license mechanism in the new RS 5.10.
So it is very importent that you install the new RS 5.10 aswell.
Tonje Sandberg
Hello Tonje,
I am confused by your 2 last posts.
I would suggest that someone create an IMPORTANT TOPIC in the RobotStudio forum that state cleary what we need to uninstall and what we can keep. For my part I didn't take any chances and I uninstalled everything.
Thanks,
Jet
Jet,
Janin Delorme, Ing. (P.Eng)0 -
Hi Jet,
What Tonje says is that you should install the new version of RobotStudio, RobotWare and RobotStudio Online.
But it is not necessary to uninstall the old versions manually first, because the installation take care of that.
ABB Robotics0
- 345 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
