Flexpendant freeze
I've made an application that runs very well. There is only one problem.
After the applications window has been open for 20 to 30 hours in the flexpendant the flexpendant freeze completly.
After swithching the mainpower off and on again everything is ok again.
I've heard that memoryleak can make this kind of things.
I'm using 'dispose' but maybe in a wrong way...
Is there someone that knows about this things that wants to look at my code to find out what's wrong?
// Magnus Johnson
Have you figured out what caused the hangings?
You can use the search tab in the User's Guide and write "hanging", and see it any of the hits may be relevant in your case.
The User's Guide also has a section called "Robust FlexPendant Applications - Memory management", which may help you to figure out how to better release memory.
If you found that your problem was not described in the User's Guide, I will gladly receive the feedback and add any missing information.
Ingela2008-2-26 18:8:12Best regards,
Ingela Brorsson
ABB Robotics, Sweden0
