Change Service Port on S4C+
How can we change S4C+ Service Port IP ?
Regards
  • You can not change the IP address on the service port, why do you not use the Ethernet port ?
    Regards
    Knud Erik Lindberg
    Danrobotics
  • Hi Mr Knud
    How can we connect the Ethernet Port with my Computer ?
    Could you send Pc and Controller Network Settings ?
    Regards
  • Hi
      Set up your net card to:
    Addr   192.168.125.82
    Sub :  255.255.255.240
    Gate   192.168.125.81
    BR
    Regards
    Knud Erik Lindberg
    Danrobotics
  • Dear Knud
    Thank you so much for your quickly response
    Actually our goal is connecting the two or three controller simultaneously with one PC ?
    Do we have to do make any changing on the controller with X start for each controller ?
    Regards
