Change Service Port on S4C+
sinan78
How can we change S4C+ Service Port IP ?
Regards
You can not change the IP address on the service port, why do you not use the Ethernet port ?Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
Hi Mr Knud
How can we connect the Ethernet Port with my Computer ?
Could you send Pc and Controller Network Settings ?
Regards
Set up your net card to:
Addr 192.168.125.82
Sub : 255.255.255.240
Gate 192.168.125.81
BR
Regards
Knud Erik Lindberg
Dear Knud
Thank you so much for your quickly response
Actually our goal is connecting the two or three controller simultaneously with one PC ?
Do we have to do make any changing on the controller with X start for each controller ?
Regards
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
