IRB 6400 backup
wakal
Hi, I want to backup 8 robots (IRB 6400). I already have them in a network and the ping for each one was succesfull. What software do I need to backup them? Do i need abbs4dde? What configuration do I need? The Ip addresses are as follow:
PC: 100.100.140.1
Rob1: 100.100.140.10
Rob2: 100.100.140.20
Rob3: 100.100.140.30,.... and so on until Rob 8
Greetings and thanks for your help.
I have researched and found that I can make the backup and mount programas in the robot with NFS server.
What NFS server do you recommend me?
What do I need to configurate the server?
Do I need to configure something in the IRB if the ping reply was already succesfull?
Thanks for your comments...
