CREATE SEARCH INSTRUCTION [ArcWelding PowerPac]
If i create a search 1d i have problems with moving the tool around the y-axis.
it is like the angel is defined by RS and it is not possible to move the tool into another angel around the y-axis.
what am i doing wrong??
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
  •  Hi
    iahve now foundt out that i can do it by makeing "rotation around this x-axis" active in the modify target window.
    Kent Zibrandtsen
