I need a easy TCP communication example
these are my first steps with Robot Application Builder.
I need an easy Ethernet-communication-example.
thanks
  • Can you be more specific about you want to do? Most if not all of the communucations infrastrucutre is built-in to the objects of RAB and the runtime platform that it sits atop.
    Russell Drown
  • I want to start/stop a roboter program from a PC-application via VS2005 and RAB.
  • You would use the controller object and establish a connection to the robot you wish to connect to. The commmunications for doing this is all encapsulated in RAB assemblies.
    You do need to have the PC INterface option installed on the robot.
    Refer to the documentation and installed samples that come with RAB for more information about how to get started.
    Russell Drown
