Connecting PC & IRB 1400
riph
Hi there, I'm new here. I hope that someone can help me with my problems over the IRB 1400.
How can I connect PC & the controller so I can control the robot directly using my PC. Do I use PROFIBUS, ethernet, serial, etc. Which way is the best way to connect the PC and controller? What is the plus and minus for each method? Please tell me step-by-step how to do the connection between the PC and the control unit, as well as the requirement to do that.
Second question, when I have successfully connect the PC and the control unit, what program should I use to control it? What is the use of RAP and RAPID?
Thank you in advance
THis topic is discussed in several places elsewhere in this forum. Try searching for PC, RAB,etc.Russell Drown0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
