AVI movie file with line tracking
Hello,  I am trying to make an AVI movie file for a line tracking station.  When I try to create the AVI and I start the conveyor, the robot seems to fall behind with tracking the part.  Has anyone else tried this, and if so, any suggestions to make this work properly.  I have also tried this using SnagIt.  The same thing happens with this too.
Thanks,
Bob
  • Hi
    There are a couple of settings in the avi recorder that you can play with (avi capture options button)
    The settings I use in most of the cases is
    - Capture Frame Rate = 10
    - Playback Frame Rate = 30
    Per Svensson
    Company Specialist
    ABB Automation Technology Products
  • Hello Bob,
    In the Conveyor Setup there is a setting called "Compensation Distance". This setting can you use if the robot miss the targets when you run a simulation with a conveyor.
    ABB Robotics
