S4C+ LAN strange problen
I met with a strange LAN problem. I have to set up a network as bellow:
robot1: IP=192.168.100.101
submask=255.255.255.0
Gateway=192.168.100.100
robot2: IP=192.168.100.102
MY PC: IP=192.168.100.100
If I use a Cisco router: Catalyst 2960 , network is OK and Ping robot no problem.
But if I use a hub, or a switch, D_Link DES 1008D, I can not ping from PC to robot . Always get time out return.
My robot is S4C+ system.
I got mad with this strange problem. Does it really necessary to use a advanced Router like Cisco 2960? I am using C type IP adress, shoud be ok with a switch.
Anybody can help me with some information?
What happens if you change the gateway to something else like 192.168.100.1 or just leave it empty?
I think the issue could be that the cisco router manage to handle the door(gateway,which is your pc) to another subnet but not a simple hub.Per Svensson
Consat Engineering0 -
if you use hub/switch try this;
Gateway=192.168.100.101
Gateway=192.168.100.102
MY PC: IP=192.168.100.105
Gateway=empty
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
