Variable robtarget name
Is it possible to define a variable robtarget name and use it?
Something like:
VAR STRING targetname;
VAR robtarget target1:=[[0,0,0],[...etc
VAR robtarget target2:=[[0,0,0],[...etc
VAR robtarget target100:=[[0,0,0],[...etc
VAR num x{100}:={0,0,0,0,....,0};
FOR i FROM 1 TO 100 DO
targetname:="target"+NumToStr(i,0);
x{i}:=targetname.trans.x+10;
ENDFOR
in your code targetname is a string varibale, can't use targetname.trans.x
where do u use this program? maybe u can find other way to program.
Peter_ABB2008-4-16 15:54:45Peter0 -
Sorry, that code won't be possible, late binding is only valid for procedure calls and such. You'd like something like .Net's 'FOREACH (Robtarget rt in ...)'
Are you just trying to add 10mm to the x value of each target in the array? Just put all the targets in the array to begin with, and then go:
VAR num x{100}:=[[0,0,0,0,....,0] ... ];
FOR i FROM 1 TO Dim(x,1) DO
x{i}.trans.x:=x{i}.trans.x+10;
ENDFOR
hi,
with the option advanced rapid you can use the instruction getdataval.
Then your programm can look so:
VAR robtarget targetname;
GetDataVal "target"+NumToStr(i,0),targetname;
ENDFOR
Thilbi2008-6-17 11:21:480 -
Thats a nice solution Thilbi, didn't think of that!
Just a note, as of 2008, Advanced Rapid is included in the standard robotware.
aNoRSWE2008-6-18 9:20:20
