Length of Identifiers/Signal Names
addi
Hi all,
someone told me that it is now possible to set signal names longer than 16 characters in RWare5.?
If this is true for signal names(?) is it then also true for arbitrary identifiers in RAPID code ?
In which RWare release did that change ?
Thanks in advance for any infos
addi
Yes both signal names and identifiers can be 32 chars now, starting I believe with 5.09.Russell Drown0
