RS 5.10 crash
Ever since I have used Set Task Frame to use an irb1600 on a pedestal, RobotStudio crashes when I try to create a workobject.
I can open the station, import a geometry but when I press the 'Create' button after entering the value to define the workobject RS crashes.
I am using RS 5.10.2400.147 and RW 5.10.1040.01.
I have found a workaround; If I prevent the controller to start when I open the station and create the WObj, then I can start the controller, synchronize and continue working with the station.
Is this a known problem with RS 5.10?
Hi Abenaki,
Sorry to hear about your problems. I am not aware of this problem from before.
Are there any log files generated? In that case, please send them to me at henrik.berlin@se.abb.com. I would appreciate if you can attach the station as well (in Pack&Go format). Just exclude any potentially confidential geometries.
ABB0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
