Arcweld PowerPac 4.0
DanS
I have a customer that tried to open a station from RS3.2 (just upgraded to 4.0). He's telling me he cannot scroll to see all his paths in ArcWeld PowerPac...the paths simply run off the bottom of the window. Anyone else seen this?
Thanks,
Dan.
Hello DanS,
Before opening AWPP there are 2 buttons in the left upper corner. Press the up button until you see a progress bar down in the window. Now the window has the correct size. You can also use these buttons after AWPP has started.
BR / Henrik
Worked perfectly,
Thank you much.
- 364 IRC5
- 83 OmniCore
