WorkObject [ArcWelding PowerPac]
Hello!
I making program in Pack&Go FlexArc cell-MM+250R (working with workobjects), but when i try to jump to the target i always get error Path That moves the object is not open. Does eny one know what is wrong.
Thank you
Domen
  • Hi,
    if you are jumping to a target which is part of a Multi Move instruction I think you need to open all involved paths in the Path View.
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • Hi
    it is because that the workobjekt you are programming in is not the one you have chosen in the top of the screen in RS layout.
    if you want me to sent you a screendump,please let me know :)
    Kent Zibrandtsen
    Dept manager robot welding
    Kez@hardi-international.com
  • Hello, Hardikez
    It will  be nice that you send me that screendump.
    Dome
    domen.perat@si.abb.com
    RolfBenz2008-5-26 13:37:33
