RS 2008 Load Program
It appears that RS 2008 will not load an S4c style program.  The dialog boxes open, and i can select a prg file, but the program does not load.  Is this a known issue?
  • Hi Pat,
    Thank you for bringing this limitation to our attention. This is definitely a bug that we will fix in the 5.11 release. As a workaround, you can load the program from the Virtual FlexPendant.
    Kind regards,
    Henrik Berlin2008-5-27 12:58:50
    ABB
  • Hi,
    Thanks for the quick response.  I don't think I was clear enough in first post.  It's the online part of RS2008 that won't load the S4 prg.  Therefore, I have reverted back to RS Online.  Pity, because RS2008 looked pretty good so far.
  • OK, so the suggested workaround is not really applicable for you then. But, once the program is loaded it should be possible to use RS 2008 again for program modification.
    I am glad to hear that you appreciate the new look and feel of RS/RSO.
    ABB
