Warning RSO in RS2008
PerSvensson
Just want to let you know that you should be carefull using Online(RSO) in RS2008.
This means when you are working against a real controller.
Did a backup using Online against a real controller running 5.09 and it made the controller to go to System Failure and after restart all the programs where blown out.
But of course I had made a backup using released RSO 5.10 before so no harm done.
Per Svensson
Consat Engineering
Consat Engineering
Interesting.... I have used RS 2008 to back up a live controller, running 5.10 with no sys failures. Maybe it's just an issue with 5.09?0
We will investigate this issue immediately. Can you please provide information on the circumstances?
ABB0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
