FileTransfer Dialog
I love the new layout and look and feel, you guys really nailed it!
There is one detail that I see which adversely affects me that would be great if worked like RSO, however.
Is there a technical reason why the File Transfer window is now a modal dialog instead of a dockable window?
This change from the style in RSO makes it much less useful for me for development purposes. For RAB development with RSO, I can simply toggle back and forth from file management tab for deployment to terminal tab for console output.
With the new setup, I have to open file transfer dialog every time, resize the window, deploy my files, close the window, and if I want to see some other aspect of Online functionality, I have to close the dialog, do my thing, and then repeat the process again.
This may seem like a small annoyance, but I may deploy and restart the FlexPendant 50 times or more in a day, so it is adds up to a lot of extra clicks.
RussD2008-5-31 23:31:40Comments
Hi Russell,
I was wondering the same thing myself, and it seems it was just a mistake in the RSO integration
Will be fixed in 5.11!
regards,
Johannes
Johannes Weiman
ABB Robotics0
- 858 RAPID Programming
