[API] AddTabbed
Grrzzz
I am having a problem with the AddTabbed Method found in UIEnvironment.Windows .
How do I have to use the 2nd parameter and for what?
All I want to do is adding a new tab in the main tab selection.
This is what I came up with so far.
ToolWindow tw = new ToolWindow();
tw.Caption = "MyTabbedToolwindow";
System.Windows.Forms.Button b = new System.Windows.Forms.Button();
b.Text = "ClickMe";
tw.Control = b;
UIEnvironment.Windows.AddTabbed(tw, tw2);
So what or where is tw2?!
b.Text = "ClickMe";
tw.Control = b;
The referenceWindow parameter is needed to specify the tab group to which you want to add the window. To add a tab beside the object browser, you should do like this:
UIEnvironment.Windows["ObjectBrowser"] as ToolWindow);
regards,
Johannes
Johannes Weiman
ABB Robotics0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
